3.0L TKS stuck in base timing
Dremmick1985
I was checking base timing by starting engine and bringing up to operating temp then jumper the 2 white dist wires together and bypass the shift interrupt wires. After timing was set I reconnected shift interrupt wire and removed jumper from distributor. The engine would not come out of base timing mode, which in the past it would.
achris
More fish than mountain goat
Turn it off and restart it. Did it come out of Base Mode then?
achris
Recheck the interrupt switch is connected properly.
Dremmick1985
the interrupt switch is hooked up properly. purple wire going to one of the black leads and the white with green stripe going to the other black lead.
