3.0l merc interrupter switch
jonoman69
I have a 99 bayliner 1750 capri with a 3l. I just adjusted the shift cables because it wasn't going into first gear. But I didn't notice the interrupter kicking in when shifting in and out of gear. If you push the interrupter button in it well stall the engine. I did this while in the driveway hooked up to the muffs. Should it be doing snything different. Also when I put it in gear there is a quick grind is this normal out of the water? Thanks
Re: 3.0l merc interrupter switch
Ayuh,... That switch only works when comin' Out of gear, 'n only In the water...
Sounds normal to me...
Taz59
Best checking it in water,the prop has to have a little load on it,
