brucetech09
- May 8, 2018
- 19
Soooo I found this site while trying to fix my boat. I have a 1999 3.0L Merc, freshwater only. Last season I was getting an overheat at high RPM 200+ degrees. I have a 160 thermostat. I assumed it was the impeller so I had that changed (housing as well) and I changed the thermostat myself. Low speeds it sits at 160 and high speed it USE to sit at 170 or so. Now it goes to at least 180 and climbs from there. I pulled the riser and it looks perfect, so I reinstalled with a new gasket. We have had the boat in the family since new. I have ruled out impeller, thermostat. The riser and manifold looked clear. the water circulating pump didnt look to be leaking. The hoses looked good. My thought was maybe the water intake hose is collapsing???? I really do not know. the season before it was perfect. last year it started overheating.
