I have an 86 OMC 3.0L cobra in my 19' boat.<br />It was running bad and I found out the manifold rusted through getting water in the engine. I got a new manifold and had the engine rebuilt. Now it runs great, but it does not idle well, especially after a hard run. It will run slow, just not at idle and it stalls when going from forward to reverse. Trying to idle around to pick up a skiier is would be very dangerous. It makes docking a very embarassing event as I have no "brake" <br />I tried adjusting/cleaning the carb. Had the marina check it out prior to putting it in this spring. It seems to work OK under no load so they did not find anything. Also I discontcted the shift interupter just to rule that out. <br /><br />Any advice welcome.
