3.0 Mercruiser alpha one gen 2 gear ratio?
jesse campbe
Hello everyone,
I have a 1997 mercruiser alpha one gen 2 I/O 3.0 4 cyl. 135hp. I recently had an accident where my outdrive came off the back of the boat... believe the gear ratio is 1:94, or 1:98??? but my questions is can i use a 2003 mercruiser alpha one gen 2 2:00 gear ratio because thats all i have?? or can i change the shaft and u joint section to match up? Please Help!!! boat sitting and the fish are biting!!! Thanks...
~ Jesse C.
Re: 3.0 Mercruiser alpha one gen 2 gear ratio?
Ayuh,...
Another Gen.II with 2:1s should be a Plug,+ Play....
jesse campbe
Thanks!!! i will let you know how things go....gonna get the gaskets and o rings today!!!
Uraijit
Banned
Wow, how does a drive just "come off the boat"? I gotta hear this story! :eek:
Don S
I've seen drives ripped off before, but it always requiered a new transom shield, gimbal ring, and bellhousing, as things were always bent, broken or cracked.
