blacklab75
- Apr 25, 2009
- 12
I have a Searay 1996 Merc 3 that is acting like its starving for fuel. It runs fine at idle but, when I accelarate past 2500 rpms it starts to bog and stutter.
I thought it was bad gas so I topped off the tank (10 gallons) and also put some stabilizer in it. Then, just to be sure I cleaned the carb with some spray and the also the flame arrestor. Went back out and it all seemed to be fine.
However, the next time I took the boat out it ran fine for about a half hour and the stuttering returned. I put some more fresh gas in (five gallons) and tested the boat out in the driveway with the muffs on. It ran fine.
So, I back to the water I go again and it starts stuttering. I also noticed that when it got choppy and the boat rocked the engine would sputter.
I 'm thinking it could be a bad fuel pump. Does it sound like this is whats causing my problems? If so, the current pump does not have a water seperater on it. Can I install a new pump with the water seperator on it as well?
