I have a new boat with 17 hours on it and since new it stumbles the first time you accelerate. The engine is up to temp--175 degrees. The stumble is less on second/third accels but never goes completely away. If you let the boat sit for 20 minutes the problem reoccurs. The dealer changed the arm position on the accelerator pump but it only got a little better. Also the engine "hunts" at 3200 RPM.<br />Any thoughts?<br />Thanks
