Tail_Gunner
- Jan 13, 2006
- 6,237
Finally i have the time to get to the motor on this boat. The issue that i am seeing is the water being vented out of the sterndrive, that is there are two vent's that water can port from and only one is venting. (upper unit)<br /><br /> I assume this mean's the water shutter has degraded and somehow found it's way into the port and if this is so could it possible to just reverse or back flush the part out?<br /><br /> Well im asking i may as well ask this also, this gen ll supposedly has a permalube shaft in it. Does one just check for roughness,can one lube the knuckle's (used to be able to put a zerk in them year's ago)Is there any means of testing for failure or do you just let them start to make a racket indicating failure?
