Hey guys I have a mercruiser 3.0 with an oil pressure issue. started at the unit and tested the gauge which is functioning. I just replaced the sending unit due to the amount of corrsion the was on the underside of it. Now when out running the boat I had steady pressure up to 3000 rpm then after it nearly dropped to 0 when running full throttle. I cut back when I saw the issue and limped back to dock. I checked the oil and seems very runny and has a fuel smell. no milky oil whatsoever. I read to check the fuel pump diaphram so I pulled the pump and had a good look at it which has no rupture signs and the clear tube going from pump to carb is clear. I'm thinking im losing pressure because of my oil being thinned out by fuel. the other culprit may be the carb?? the boat wants to fall on it's face during acceleration also. compression test solid across the board. Has this happened to anyone before?? just looking to get pointed in the right direction.
Thanks in advance guys!!!!
