Hello,<br />I have a 2004 Mercruiser 3.0 liter that is idling at about 900 rpm. My manual says that I should be around 650-700 rpm. My question to the Mercruiser techs is regarding the "tamper proof" idle mixture needle. Can I lower the idle 200 rpm with the idle speed screw without adjusting the idle mixture? Is the idle mixture needle preset from mercruiser or does the dealer adjust it at setup? Finally, will there be anything that will indicate that I am running a slightly rich or lean mixture other than a rough idle.<br />Thank You in advance!
