3.0 L Exhaust Manifold Conversion Adaptor
szn9rg
I have a new 07' 3.0 L GM Vortec engine which has 8 port openings in the head. The OMC exhaust manifold off old engine has 5 openings. Prior engine was a 92' 3.0 L GM engine. I was told there should be no difference after 90'. The 3 center openings are longer and combine 2 ports each from the new block. I've been told that there is a exhaust manifold conversion adaptor to match the 2 up. I've been looking but can't find any such thing. Does anyone know where I can get one of these or do I have to look at buying a new manifold. If this is the case, any cheap places to look? Also how can I put a picture with the message. The size of the picture is much larger than the rules permit. As you can tell I'm ready to go crazy!!!!!!!!!
Thanks for everything
leakdoctor
Re: 3.0 L Exhaust Manifold Conversion Adaptor
I can't help with the manifold, but I can help with the pictures. Just Google "Picture Resizer." There are all kinds of free sights that you can upload your picture to, reduce its size, then download it again. There are also free programs that you can download to your computer to do it.
szn9rg
Thanks, I'll give this a try and maybe I can post a picture the shows the 2 different gaskets.
It Should just Bolt Up,+ Run,.......
I admit that I haven't seen an 07 3.0l Head,......
Chevy has changed the size,+ location of those ports several times over the last 40 years,.....
But,.......
They're All still a Bolt on interchangable situation.......
