3.0 EST Timing - Total Spark Advance Confusion
swamplynx
We all know there is a special procedure you need to set the timing on 3.0 EST ignition systems, by jumping into base timing mode, and then set the base timing to either 1 BTDC, 1 ATDC, or 2 ATDC depending on SN. This all makes since, but what I don't understand is how setting the base timing more retarded is supposed to equate to a more advanced run timing. From service manual #26, and also #46:
• If initial timing is 1° BTDC: 12° BTDC, plus or minus 2°. At 2400-2800 rpm maximum
(total) advance is obtained and should be 23° BTDC (plus or minus 2°).
• If initial timing is 1° ATDC: 14° BTDC, plus or minus 2°. At 2400-2800 rpm maximum
(total) advance is obtained and should be 25° BTDC (plus or minus 2°).
• If initial timing is 2° ATDC: 15° BTDC, plus or minus 2°. At 2400-2800 rpm maximum
(total) advance is obtained and should be 26° BTDC (plus or minus 2°).
They all use the same EST module, so how is less advance in base timing supposed to create more advance in actual run timing? The advance curves show the same conundrum as above.
The newer engines are speced to 2 ATDC, which is presumably for less advanced timing in the newer higher compression 3.0s to avoid blowing out head gaskets, but the above (and the advance curves) seem to indicate a the actual run timing should be more advanced than the older 3.0s speced to 1 BTDC in base?
Are these advance curves in error? What should the actual run timing curve be for a 3.0 with a 2 ATDC spec? My testing on two different 3.0s that setting the base timing to 2 ATDC will not give you the at idle advance or full advance shown in the published advance curve (you end up closer to 24 BTDC at full advance).
Thanks for the insight.
TurtleTamer
Great post, though I don't have the answer. Mine is spec'd at 1* ATDC but as long as it's not lean it will handle a lot more advance than that. I really don't think it's an issue until you get to altitude or load it up, or start having fuel problems.
That being said, I keep mine at 1* ATDC (base at idle)
swamplynx
Out of curiosity what year engine and what timing at total advance did that incident occur at?
Bt Doctur
a late model TKS IL 4 .PO unplugged the TKS and bumped the timing 6 deg..New owner just wanted to see how fast it went
swamplynx
Old thread, but I think I answered my own question... The Merc documentation is simply inaccurate. Looking at the Penta docs for the same engine, you'll see:
3.0 All Models1 Engine RPM . . . . . . . . . . . . . . . . . . . 86 AKI Fuel
Initial . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .-2°
600 RPM . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8°
1000 RPM . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13°
1500 RPM . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15°
2000 RPM . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17°
2500 RPM . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18°
3000 RPM . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19°
3500 RPM . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20°
4000 RPM . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20°
4600 RPM . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21°
...which is the advance curve I am seeing in my 3.0 TKS. Thanks Merc for putting out bum documentation.
