Hello everyone, I'm new to these forums as I just got my first little outboard.
Its a 1992 Suzuki DT-2, 2 stroke, 1 cylinder, 25lbs.
I'm using it on a 12ft intex inflatable.
The engine runs fine, but its really slow.
I have found in the local classifieds a 1988 Johnson 4 HP, 2 stroke 2 cylinder, 50lbs.
My question is whether or not this motor will be significantly faster than the Suzuki?
I'm pretty sure the Suzuki is underpowered for the boat. There is no difference between 1/2 throttle and full throttle, like its bogging down a bit. The engine runs perfectly, and is super clean and was not used much so I think its running as well as it can. Can a sparkplug change make a difference even if it looks good?
Thanks in advance, I don't want to spend 400$ I can't really afford on a motor and be disappointed.
