Re: 272 boss prop ?
It's likely a 1.5 ratio.
My Scarab is 27 feet (26.9) and had the same issue.
Low 60's is what the 502 and Bravo 1 on a 1.5 drive ratio can do on these deep V's around 26-27' in length. You could drop down in pitch to a 23p and raise the RPMs, but top speed might not move by more than 1-2 MPH.
I got my RPMs up and speed up a couple of MPH from going 25p to 23p, but the 50-60 range came alive, so it was worth it. Engine gets up near 4900 RPMs now.
No matter how you slice it and dice it, these 27-foot boats with a 502 are low 60's boats. They just are. 60-65 is the typical/normal range, give or take an MPH for different hulls, conditions, etc.
You might be better off just getting the current prop labbed. It's close enough the way it is. I think I'd look at that since it's already a Mirage Plus and you are at the (bottom) edge of the WOT operating RPM range anyway.
A prop shop can add the RPMs and maybe address the cavitation issue, and you'll get a little more top end. I had a basic Mirage, not Plus, so I didn't opt for labbing. I was better off getting a new Mirage Plus at 23p. I'd have the engine declared healthy and consider labbing if I were you.
