270 Volvo outdrive What kind of lub goes in and where
pathfinderz1
Help
270 Volvo outdrive:)
Took the lower unit off and need to replace some of the lub lost. What kind goes in it
Thanks
Mike
JAL51974
Re: 270 Volvo outdrive What kind of lub goes in and where
It calls for 30w oil same as used in the engine on my AQ125A.
jerryjerry05
Under the back cover is a hex head bolt/screw/nut.5/16 I believe. Remove the top dipstick and fill from the hexhead( BSN).If your topping it off and it aint been done in a while change it completely.Straight 30wt is what it takes. Jerry
texted
If it's been in storage for three years can I do the same to maintain it? I don't want to hit the lake and find that it's dry. how do I check it?
