When posting a question about propellers, you cannot get a reasonable answer unless you provide the following information in your post: Items 1-4 are essential for meaningful response to most questions.
1) Performance issue you are trying to correct.
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
3) Current prop diameter and pitch (required).
4) Wide open throttle RPM and speed with an average load (very helpful)
5) Engine/drive make, model, year, and HP
6) Boat make model, year, length and weight
Butch nice boat really nice boat..I know its annoying but as Phil said to get you smiling the info is needed. I know there are very inexpensive digital tach's some place...I believe you can reant one from Oriley's..I have a personal friend with a 26' Rinell for years he resisted doing the above...Finally got him on the water...That boat went from 54 to 62 and he still doesnt buy the beer..
But lets do this...25p @ 4800 with 1.50 gearing nets 76mph...@ 12% slip your at 67mph
And this...25p @ 4800 with 1.32 gearing nets 86mph...@ 12% slip your at 76mph
If thats aq Mag with a bravo drive your hunting...But there is know way of knowing if your combo can push that.
