25m Mariner Throttle Question
Jakestg
mariner 25M 1984
serial # 695 S 023835
Need help hooking up throttle controls. I rigged the shift controls good but I can't figure out the throttle. I know it's possible but I need some pointers or direction to parts. The rest of my photos will not post. I disconnected the tiller cables to that circular piece. Are there any parts to install throttle? I have controls and wires with the circular plastic piece at the ends. I also see a accessory port on the front right side. There is also a oval piece on the right outside of the motor. I tried rigging that but no go. Thank you!
oldman570
Re: 25m Mariner Throttle Question
The motor dose look like a 1984 year motor, but the SR# you gave is wrong and not in my book for the motor. It looks like the S is not correct and might be something else. My listings show that it should be all numbers. If you are trying to hook up the motor for tiller steer, there are parts that looks like they are missing in the photo. Here is a link to a diagram of the parts needed for a tiller setup.
Mercury, Mercruiser, Force, etc. - THROTTLE AND SHIFT LINKAGE (MARINER)(MANUAL) - 18/20/25 H.P. (XD)
Look at items 9 thru 13 that hooks to the carb rocker plate. Then look at the other rod that hooks to the stator plate , and the one that hooks to the shift linkage. This should give you an idea as to how and what is needed to fix the troubles for a tiller setup. JMO
Oldman570
