Was out in the skiff this weekend. It's an electric start.
When I pushed the button I could hear an electrical pop from where the positive battery cable joins the motor. Very faint pop. Couldn't hear it until I had the cover off. I pushed it for maybe the fifth or sixth time and it started right up. Basically had the same problem all day. Five to six tries then it would start no problem. Nothing like it before.
Getting ready to leave for the day, same problem, and this could be totally unrelated, but this time after it started and I put it in forward the boat went nowhere. I thought I was grassed so I put it in reverse to clear the prop and there was a crunching sound and then the prop started spinning. By that time I'd taken it out of gear and shut the motor down. Decided to give it another whirl, but this time the motor started right up without the hesitation. When I put it in Fwd it acted normal but as re putted down river I'd occasionally hear a slight grinding sound as if it were being shoved into reverse even though there was never any loss of power. Each of the times I stopped when it did that the motor restarted fine.
I think I have two problems here.
