25hp Mercury spark plug wire problem
Burton159
I have a 1994 25hp Mercury outboard serial #OD292598. I'm was trying to change the original plug wires. On the coil side I thought you just cut the cable tie and pulled the old wire out. I did that and just the wire came out not the brass end? Did I do something wrong or should I just try pulling the brass piece out with a pair of needle nose?
