I suspected that my engine was running hot so I took it out and checked the surface temp of the power head after running WOT. My gun read 200'F. The manual says over 165'F is a problem so there you are. I have already replaced the impeller and thormo so now what? I noticed that there is water pumping out of two holes just above the lower gear unit,is that normal. Any suggestions would be appreciated.
