Unclekoolaid1
- Oct 28, 2011
- 2
My motor has just started having problems. Its a 2002 2 stroke 25hp Mercury. CARB: (20/25/JET 20 SEAPRO/MARATHON 15XD SUPER 15/JET20) (2-STROKE)
When starting you have to pull the choke in and out multiple times and then pull start. Once it is started it runs rich but then sputters and kills after a few seconds. The way i stop this is when it sounds like it is killing i pull the choke in and out while running and once you put the motor in gear it will run perfect for miles without sputtering until you idle and the the process continues. I have changed spark plugs and soaked what looked to be like an already clean carb. I do notice that when you pull the choke it primes the carb and it looks a little leaky. Could it be my seals? I have a new gasket set and have yet to put it on. Looking for any other solutions while i have the carb apart.
By the way i take the boat out almost every weekend and i have seen fuel run through the filter and the line.
Thanks,
Taylor
Thanks,
Taylor
