i have a 25hp 2stroke short shaft tiller handle tohatsu mounted on a 1436 tracker jon boat 14' long the problem is when running on plane it shoots water out the sides at the motor bad and it pushes the front of the boat down in the water on the 3rd pin hole from the top and if i put it in the 4th pin hole it starts sucking air and over rev's i have picked the motor up on the transom in several different spots but have not been able to get the sweet spot can anybody give me any suggestions? thank Allen also when i say it shoots water at the motor it shoots it so bad that if i were to ride by you in your boat you and everything in your boat would be wet! thanks again Allen
