Ok guys..here's an update.. (figured i'd start a new thread since this is a new problem)
I cut off the dead rectifier...cleaned the carb...dumped my fuel and got fresh fuel..added the oil and some sta-bil....cleaned the fuel filter.....then pulled the rope.
Motor started on the first pull.. I let it run for 20 minutes or so.
I then hooked up the battery....cranked the motor...it would not start(turns the motor fine..just wont fire).. I pulled the rope..it still will not start...
I disconnected the battery and it starts on the first pull.
So now the motor runs fine but will only start if the battery is disconnected....i tried both of my batteries..they both have a full charge....
HELP!!!
HELP!!!
