Mark Noteware
- Aug 2, 2004
- 8
I have water flow at idle speed and as motor approaches about 3000 rpm, the water flow from the exhaust ports stops. Tattletale keeps flowing.<br />Now the weird part..... I have replaced the water pump and still have the same problem, and I have replaced the thermostat and still have the same problem. An old sage told me to check the head gasket as if there is a break between the compression and the water jacket, the exhaust pressure could possibly restrict the water flow. This has been replaced also. Any ideas ?<br />Thanks in advance.<br />Mark
