After reading many post on this and getting confused on how to change the timing from 20 to 25 degrees I have come to the conclusion that to do this conversion I need to
1- Change Gasket behind carby
2- Make sure throttle is opening all the way by adjusting stopper(This automatically advances timing to 25 degrees)
That's it
If someone can confirm this that would be great . I cannot see how you change the timing position as per markings on motor from 20 deg to 25 deg without altering the advancer arm rod length as shown in picture below.Most posts say not to alter this at all?
My motor is set to 20 deg ,the same as the above picture .If I have to move it to 25deg can someone tell me how to do it
Regards Kevin
That's it
Regards Kevin
