I think I'm having multiple issues with my motor (2000 25hp Johnson). Like I mentioned in my previous posts this motor just won't run properly. I took the lower end of today and it is full of oily grey sludge. I have checked spark few times with a spark tester and 7/16" gap and spark is bright blue on both cylinders. Compression is about 110 psi on both cylinders. Carb is rebuild and clean. Fuel pump is also checked.
I was wondering that is it possible that the power pack is giving low voltage or somehow giving random spark so that it is preventing proper firing and causing the grey sludge to form? I checked the coils for resistance and both gave 0.1 ohm on primary and 245 ohms on secondary side. I have also tried a pack from another motor and it didn't change anything. But when I tried my other motor (88' 20hp Evinrude) with these packs it had same kind of idle problem! And that motor ran great last year. So something very weird is going on...
Any thoughts?
Thanks
Any thoughts?
Thanks
