I have been messing with some wiring due to motor not starting with ignition switch. Finally, I replaced the battery cables and solved my issue. Today, I tested out the new cables and was able to get the motor started. I was feeling pretty good since I have always had to pull start it since I have had the boat. I turned the key off and the motor kept running. I unplugged both battery cables and it still kept running. Finally, I unplugged the gas and a few minutes later it ran out of gas and stopped. Not sure what the problem could be. Any ideas would be greatly appreciated!
