25 Evinrude waterpump HELP !!
Hdg2018
Hi everybody!! Just joined today. I currently own a 1984 25hp Evinrude. Long shaft. Pull start. My question is this. While I am running the boat at idle, I have water stream at ore hole. When I put her up on plane, she stops streaming water. Impeller/water pump replacement? Has anybody seen this behavior before. Thanks for any help
F_R
Honorary Supreme Mariner
Are you asking about the "pee" hole or the exhaust relief holes? Since you haven't burned it up yet, it probably is pumping ok. But the pee hole should squirt any time it is running.
If you have any doubt at all about the impeller, replace it.
Are the water inlet screens present on the sides of the gearcase? That could be a cause of failure to cool at high speeds.
Hdg2018
Yes. I am referring to the “pee” hole. At idle she streams water. Also, I have water coming out of back of motor where exhaust exits. But when I put boat on plane, she stops pumping. There’s no screen on intakes. The previous owner removed them.
