dodgezilla04
- Jun 3, 2009
- 21
The boat is a 2300sc 2002 bravo3 outdrive 350 fuel injected with a closed loop coolant system(heat exchanger)
when hooking up the ear muffs, there is no raw water cooling. i removed the engine driven raw water pump and turned on the earmuffs, there is no flow through the open end of the hose. i attached the garden hose to the disconnected raw water pump suction, and there is no flow out the outdrive suction.... dumb question, is there a raw water pump in the lower unit? some web pages and the exploded drawing says no....
the maxum owners supplimental says check the seacock... i have traced the hose hand over hand from the pump to the outdrive connection, i cannot see any valve...
is the outdrive plugged up???
thanks
thanks
