225 v6 johnson
vetteman
what is the difference between left hand rotation and right hand??? will power head from left hand work on right hand lower unit?? is the difference in just the gears, are the power heads the same?? or is the lower unit what determines left or right rotation. i need to know if i can put counter rotation power head on right rotation lower unit. thanks :)
93bronco
Ensign
Re: 225 v6 johnson
i know for the 120/140 its the lower unit that makes up the counter rotation, and in a 185/200/225 parts book it shows the same. hope that helps.
vetteman
Re: 225 v6 johnson
thanks for the reply, i thought that was the way they were set up. then i saw some ads on ebay for starters for counter rotation v6 johnsons , so i thought i'd better ask someone that knew what was going on. didn't want to wast time and money and not have everything work out. :cool: thanks again.
Dhadley
Re: 225 v6 johnson
The early counter rotation OMCs actually turned the powerhead backwards. Thats where that starter came from. Nowdays the powerheads all turn the same direction. The left hand rotation is achieved in the gearcase. <br /><br />Good luck!
