225 Ficht Shutdown
Status
Not open for further replies.
vikings24
2001 3.3L 225 Rude Ram, run for 10 minutes, then shut down with one beep. Turn key and completely powerless, no going thru any gauge light synquence, only the trim will operate. The electric fuel pump booster will not even run at the time. Let cool down 15 minutes and fires right back up for 5-10 more minutes and repeat. Thought maybe EMM Over temp but Checked all water passages thru EMM, into and out of Vapor separator and strong flow all the way. Had a clog in vapor separator inlet a year ago but cleared it and no more problems until now. Could EMM have a stored code or could a sensor be causing this?? No noticeable change in gauge water pressure. Lightning gearcase, high volume, low pressure, 6-8 at idle, 16-18 at WOT. Been that since new. Any thoughts appreciated
Faztbullet
Have you checked the PDP as these are bad about solder joints breaking??????
Riverrat64
I have the same problem except I lost all trim and no power but after it sits for a while I can turn it on once but get nothing if I shut it off and try to turn it back on
Status
