20W-40 oil question
tie_one_on
I just picked up a 1988 Yamaha YFM 200 4 wheeler. The manual calls for 20W-40 oil when changing the oil. 20W-40 seems very difficult to find. Can I use 10W-40, 15W-40 or 20W-50 (all are easy to find)? Thanks.
SpinnerBait_Nut
Re: 20W-40 oil question
I always used either 10W-40 or 15W-40 in my Polaris Ranger.
i386
The dealer should carry it if you have one close by. I always get my oil, filter, and new crush washer for the drain plug from the dealer for my Honda motorcycle.
Turin
10w40 should do the trick its a bit thinner but that doesnt matter.
20W40 is loads cheaper if you can find it.
KM2
A 0-40, 10-40 would be fine. Dont' put an auto oil in, use a motorcycle/atv oil. I believe you have semi-auto transmission with a wet clutch. Friction modifiers in auto oil may cause you problems with clutch.
bruceb58
You can uses Shell Rotella. It does not have the friction reducers in it so it is fine for motorcycle engines with wet clutches that share the crankcase with the tranny. You can get it at WalMart.
tie_one_on
Thanks for the replies so far. I am confused (nothing new) by KM2's comment of not using automotive oil. I believe the manual call for 20W-40 SF/SE. Isn't this an automotive oil? What the difference? I know I'm treading on hallowed ground as this could end up in "another oil" conflict.
bruceb58
The key is that the oil has to have no friction reducers in it.
Go to a motorcycle site and this topic is always on them. Most that don't use the designated motorcycle oils use Rotella.
