Re: 20hp Mercury with no neutral?
seaweb,<br /><br />Sounds like your shift lever and cam is misaligned. In the lower unit, there is a cam that has to notches. On the highest notch is reverse, the middle notch is neutral, and anything else, including the absence of the cam is foward.<br /><br />Pull the lower unit off, and shift the controls into reverse. Turn the shift shaft on the lower unit until it is hard to turn counter clockwise. Grab some pliers and turn it some more. It should feel like it has went over a hump. If you can't turn it, move the prop back and forth a bit. On the first hump, you will likely be in Neutral. Spin the prop to check this, the prop should spin, but the shaft should not. Now turn the shift shaft another notch with the pliers. You should now be in reverse. The prop should move about 1/3 a turn in either direction before catching and turning the shaft to the powerhead.<br /><br />Then, just re-attach the powerhead to the leg. You may have to turn the prop to get the splines to line up with the powerhead when re-attaching.<br /><br />Then, hook up a hose and test that you have F-N-R<br /><br />Good luck,<br />k
