maxcapacity
- Jan 1, 2013
- 2
I've searched the forums and found a lot of discussion on converting short shaft to long shaft but didn't see anything that covered my question directly. I don't want to convert anything I just need to repair my 20HP Short Shaft using a lower unit from a long shaft motor. My lower unit housing is damaged but I've found a good used conmplete long shaft lower unit and I am wondering if using the good long shaft lower unit on my motor is as simple as swapping the drive shaft, shift shaft, water tube, etc.? Does anyone know if this can be done relatively easily?
