TheSeaFactor
Thread starter- Joined
- Jun 29, 2018
- 1
Hello everyone! I recently purchased and had installed the new Etec 250 HO (10 year warranty helped in my choice!).
The dealer who installed it told me the steering at low rpm's would be tight and smooth out with higher speeds. I've found this to be true.
My main question is, is this engine supposed to steer so stubbornly at low rpm? It makes navigating the marina a bear. Changing the engine from full port to starboard takes considerable time and swollen fingers from banging them into the steering wheel spokes as I try to quickly navigate into a mooring with wind trying to thwart my efforts.
I switched from a Mercury outboard that had external hydraulic steering that was significantly easier to steer in all conditions. I've gone from being very proficient in tight maneuvers to looking like a complete amateur due to the time it takes to move the engine around.
I'm trying to see if something wasn't installed properly (and the dealer doesn't want to fix it) or if this is simply the life of the Evinrude's.
