2016 Mercury 115hp 4 stroke
Mc Tool
Im looking at a new boat ( lookin at a few ) one has the above motor on it with 595hrs on it . I have googled a bit and it seems good to me , but the thing is 800kms away so Id like to be sure that they are a good model to start with and I cant think of a better place to ask if they are a good motor . If you guys think it is Im going to get the seller to take the boat to a local boat shop for a check of the hull and the motor ( data download ). I have never had a fuel injected outboard before ....can I get a download tool so I can see info for myself ? is there any point . I do plan to learn the motor ,buy a service manual and do my own servicing
alldodge
The Mercury non-supercharged outboards have a very good longevity rating. Don't know about the 115 in your post, but my 2023 250 Verado also has a high rating but the maintenance needed to keep it that way can get expensive quick
While I needed to replace the plugs, ALT belt and fuel filter every 100 hours or 3 years, looking at the 115 it says to inspect or replace plugs. The key is do the maintenance and they will last.
You can rent a scanner on ebay or buy one. You would need a scanner to work on the motor if it has any problems. Look at Rinda.com to find the cost for Diacom software or the TechmatePro
jlh3rd
Bought a used ‘06 pontoon in 2017 with an ‘05 60 hp merc. Big Foot.
Motor ran beautifully.
Replaced it with a new 2021 Merc 115 HP CT. Runs great.
I believe Merc. reputation is solid.
