2015 Honda BF30D
Grumbles
The #2 cylinder on this 3 cylinder engine won't fire. #1 and #3 perform properly. There is fuel on #2, but no spark. I changed the spark plugs, although they were not fouled, with no change. Any idea on the cause and method of correction?
Sea Rider
Welcome to IBoats,
Does the motor have independent ignition coil packs, or it's a 3 in 1 compact unit ? What about the CDI ?
Happy Boating
ahicks
Are the coils identical? If so, swap a couple of those around. That would tell you if it's a coil or wiring leading to the coil.
