Brought boat out of storage after 7 months. Wouldn't start and run. Replaced high pressure fuel pump. Engine runs fine at idle and WOT for over half an hour. BUT, I'm getting random warning beeps. No rhythm or pattern except Yesterday, it only did it at idle. I replaced the impeller and lower unit oil today, and now it's randomly beeping through out the RPM's. Disconnected the temp sensor and got 6 beeps after startup. Then the random beeping started again. I'm thinking it's a loose wire or bad ground, but, I'm not sure where to start. Any help is appreciated. I have some video of the beeping but couldn't upload for some reason.
