jonnorris1000
- Apr 25, 2016
- 7
I am in the process of replacing my impeller in my Merc 125 Optimax long shaft. I took the lower unit off and all was well until I noticed that I have a 5" extension housing section on the lower unit to make it a long shaft and have to take that off before being able to take the water pump housing off to replace the impeller. And it would appear to be stuck on there from the factory since this is the first time the impeller has been changed.
Problem is I can't get the extension section off the lower unit, from what I can see there are no more bolts holding it on it seems stuck. Any ideas on how to get this apart, my guess there is gasket material still holding it on usually bad things happen when I try forcing it, but perhaps I am missing something. Appreciate the help in advance.
