2010 24' bayliner 245 cruiser with 5.0TKS and Alpha One
Stinnett21
Run it through the Mercury prop selector online. The lowest pitch possible without over revving, tune the motor up, install trim tabs and say a prayer. It's very under powered for that situation.
Which ever prop gets you to 5000 RPM
with 6 people, you are probably in the 13p-15p range. you will need to test.
your boat is over 6000 wet, not including people. so you are at 7k+ if you have change in the pockets
my old searay had the same motor, and only weighted 3000 dry, about 3600 wet, with 4 people I was running a 19p. I thought my boat was underpowered.
