2008 yamaha f150 txr fuel pump problem??
Steady rippin
I turn my key on and no longer hear my fuel pump kick on prior to starting, now engine will not start. Engine was running fine last time on the water...now nothing?? Any ideas or similar issues any has or have had? Thanks for any help!
tommarvin
Ensign
If you think no fuel, you better do a fuel pressure test..
Can you hook your laptop to your motor for diagnostics and maintance, you need a cable and software too.
You can get a fuel pump rebuild kit and do it your self. youtube videos.
Are you sure there's power to fuel pump if you need power.
Steady rippin
I have no software to hook to laptop.. Not positive if im getting power to the pump, i do know the fuse for the pump is good,i even changed the fuse with a new one just to be sure.
hondam
If all the fuses are good check for voltage with a DVM.at the pump and the fuel pressure with a gauge. One of those tests will probably tell you what the problem is.
