2008 Mercury 15hp 2-Stroke - Gauges and Parts Needed
TheCharles
Hello boating community,
I am extremely new to boating and I have a 14-ft pontoon boat with a 2008 Mercury 15 hp outboard motor. I am learning new things every day about owning and operating a boat engine. It's completely different from what I'm used to, so any help would be appreciated.
A friend of mine told me that I need to have three different gauges on my pontoon boat. I have been operating my boat with out any gauges at the moment. He told me I needed the following three gauges:
  1. Volt meter
  2. Tachometer
  3. Water Pressure
On to my questions:
  • How do these gauges hook into my outboard engine?
  • I'm assuming with a certain Mercury cable, so what cable do I need to buy?
  • What brand gauges do I need to buy?
  • Are there any other gauges that I absolutely need or that you would recommend?
Thanks for your help! Ciao.
-The Charles
Dave1027
Re: 2008 Mercury 15hp 2-Stroke - Gauges and Parts Needed
I don't think you need any gauges for a 15 hp motor. Make sure it's propped correctly.
Mi duckdown
Just make sure your water impeller is good. Forget what your friend said.???
ondarvr
Most any cheap fish finder will give you the voltage, plus you'll know the depth, which is possibly more important than the other things.
Water pressure isn't important, a tach can be convenient and help in getting the right prop. A tach can be purchased here on Iboats easily.
MH Hawker
I have a tach and volt meter and a hour meter on mine. Their not hard to find o hook up. Their is a plug in out let on your controller that the instrument hook up to and depending on your motor then you see what it will except.
