2007 volvo penta trim
pugzit
2007 Glastron with 3.0,sx-a outdrive. Tilt, trim motor can hear it run, full of fluid, no movement on the rams.. Help
Ayuh,..... Welcome Aboard,..... My WAGuess is, the motor shaft broke where it goes into the pump body,.....
Probably easiest to pull the whole pump, 'n test it on the bench,....
I believe iboats carries the parts, 'n pieces for that pump,....
