I am taking the motor to the shop this afternoon, but wanted opinions, and will post results to help people in the future.
The motor is mounted on a 17'9" spectrum, aluminum hull. Has a 13.25 x 17, 4-blade SS prop.
Problem : after 10 seconds of throttle, on plane instantly, the boats bogs down as if running out of fuel. Sometimes resetting the throttle to neutral then back will give you throttle back for a second or longer. Sometimes it sounds like the motor grunts, like it wants to go but is being held back. I've tried multiple throttle positions, to see if it would run, but soon as it planes out and rpms go up, without adjusting the throttle, it will bog down at 3200-3400 every time. I can hold the boat at 3000 rpms and it runs fine, but I'm ruining everyone else's day with a 3 foot wake.
I have tried a separate gas tank, replaced fuel line to the motor, inline fuel filter, priming ball. No changes.
I will post again the mechanics findings. Thanks in advance for comments and suggestions
