2007 5.7 running rough
jlcboating
my 5.7 merc just started running rough at and idle after being rocked by waves. seems to load up. what would be the problem? Float in carb?
alldodge
Probably should be in the Merc section
Could use a tad more info. Is this a new to your boat? What kind of maintenance been done this season?
Being a 2007 you sure it has a carb? Have a motor serial number?
Ayuh,..... Welcome Aboard,...... I'd start by examinin' the Contents of the fuel filter for anything but Clean Fresh Gasoline,....
