2006 volvo penta 3.0 GLP-E OVERHEATING
num1aubfan
Hello i purchased a used 2006 sting ray 18ft. Its ran great until yesterday at the lake in idle/ no wake speed it wanted to overheat once i came out of the hope shot it cooled back down, i have read my forums on inpellers and thermostats. I feel it would be best to replace both as i have the engine diagrams. My question is when i removed the hose to the thermostat housing i looked deep into it (housing) and didnt see the thermostat or so i think i do see an oval black ring and a round thermostat looking part. How do i remove this from the housing? Will it pull out with needle nose pliers?
Thanks
Don S
Re: 2006 volvo penta 3.0 GLP-E OVERHEATING
You remove the oring that holds the thermostat up in the housing, then you can remove the thermostat.
Impellers should be replaced yearly or every other year at most.
