2006 tuhatsu oil plug
tigman
trying to change oit on a 2006 15 hp 4cycle without an owners manuel where is the drain plug?:confused:
pvanv
Re: 2006 tuhatsu oil plug
The fill/drain plug is on the port side, on approximately a 45-degree angle, below the prop shaft housing bulb. The vent/level plug is above that, adjacent to the plug that is used for the water flushing attachment. You can download an owner's manual for free at http://www.tohatsu.com/tech_info/manuals.html
