2005 Yamaha vx110 milky oil
Sunbird32
2005 Yamaha VX110 Deluxe – Water in Oil After Winterization – Six Oil Changes
I have a 2005 Yamaha VX110 Deluxe with approximately 169 hours.
During winterization, antifreeze may have been introduced through the flushing connection while the engine was off, allowing fluid to enter the engine.
I’ve now completed six oil changes, replacing the oil filter each time. The oil was initially milky, but the latest dipstick sample appears much lighter, with an amber/tan color and some remaining haze.
I’m trying to determine whether I’m successfully removing the original contamination or whether water may still be entering the oil.
For those who have dealt with this on a VX110:
  1. How many oil changes did it take before the oil was completely clear?
  2. Is gradual improvement over six or more changes typical?
  3. How can I verify that no new water is entering the engine?
  4. What diagnostic tests would you recommend before putting it back on the water?
I have pictures documenting the oil condition and can share them.
Scott06
Pressure test the cooling system. Not 100 % familiar with Yamahas but if similar to my sea doo has AF in block , and raw water in exhaust manifold. Just would need to pressure test both, if it holds pressure you are good.
definietly will take several oil changes to get contamination out.
