2005 50ELPTO constant horn when key on
qdap
Hi, For the past season, there has been a constant alarm from the ignition when the key is turned to the ON position and the engine is OFF. Previously, there was stuff in the intake which clogged the tell tale water output, which was cleaned out and now there is a stream. But there is still an alarm which is ear piecingly annoying, maybe for a reason. We have been coping with it for the season by turning the key a few degrees towards the OFF position to stop the alarm but keep the engine running. This does come with some drawbacks, the guages are shut off so I cannot monitor the engine unless I turn the key back to the ON position. The engine is filled with oil to the top and has never run out since its lifetime in use, no previous owner, and no previous problems with the engine until now. The engine does seem to over-rev sometimes and lose its catch in the water when at FULL throttle and against current, though this may be a different problem in itself.
To recap facts
PROBLEM : Constant alarm when key on
COPING: Turning key a little towards OFF, however no guage readings
PREVIOUS ISSUES WITH ENGINE: Clogged tell tale intake
CURRENT CONDITIONS: Filled with OIL
