2005 4.3L Mercruiser Dieseling (throttling up and down after shutting off) - SOLVED
Hello-I'm new to boating and have used this site extensively since buying our 2005 Sea Ray 185 Sport w/4.3L Mercruiser (60 hours) in August 2017. It had a dieseling problem right away. We'd run it hard, then turn it off and it'd throttle up and down, sputtering for a few moments before eventually dying. It's been solved though and I wanted to share the fix with the community in hopes it helps someone else.
FIX: In neutral, the boat was idling around 900 RPMs but the engine sticker said it should be at 650. So, we found the idle screw and turned it (flat head screwdriver--very easy), until the RPMs sat at just over 600. Ontop of that, we try let it cool down for a minute or two after running hard (tubing, skiing, etc.)
Since making those adjustments, no more dieseling!! Hope this works for you!
Bt Doctur
check the timing too, that can contribute to the same problem
TyeeMan
Master Chief Petty Officer
Yep, high idle will do that, as Bt Doctur said, check your timing as that can be a big factor as well. Also, I never shut down directly after a hard run, I let it idle for at least a couple minutes to cool everything down a bit.
